[Automation Suite][AKS]Scale minimum and maximum number of Automation Suite nodes when the load gets high in the cluster
How to scale minimum and maximum number of Automation Suite nodes when the load gets high in the cluster?
Issue Description: When the load gets high on the cluster, there is need to scale the number of nodes.
Resolution:
  1. Open the AKS cluster in Azure Portal
  1. On the left pane, click on Node Pools
  1. Click on three dots on right pane of agentnodepool
  1. Select "Scale node pool"
  2. Update "Minimum Node Count" & "Maximum Node Count" accordingly
