I need to order a Data Table if possible, if not I should not to be a big problem to do it directly in excel with the next logic:
Context: Imagin a Data Table with only two columns lets call it: C_One and C_Two
C_One has the type of the element, in this example it will be numbers so we will have four types: 1, 2, 3 and 4. This means that all the elements in the table will have in C_One one of those numbers.
C_Two is a string descriptor.
What I need to do is to order ascending by C_One but every 2 rows with the same type/number change to the next so if I have this:
Have to say that there are many more types in real case and number of items each type has is not equal and not even and there are like a thousand or more per run.
(From d in dtData.asEnumerable
Group d by k=Cint(d("C_One").toString.Trim) into grp=Group
Order by k
Select t = Tuple.Create(k.toString, grp.ToList)).ToDictionary(Function (t) t.Item1, Function (t) t.Item2)
(From d In dtData.asEnumerable
Group d By k=CInt(d("C_One").toString.Trim) Into grp=Group
Order By k
(From s In Enumerable.Range(0, SegmentCount)
From v In dictOrderedGroups.Values
From cr In v.Skip(s*ChunkSize).Take(ChunkSize)
Select r=cr).CopyToDataTable
