i m getting above error when i m using IN operator in datatable.select
as
dt_datatable.select(“[Item] IN ( ‘KVCARWAR-001-5000-LF’)”).CopyToDataTable
but its working perfect when i use
dt_datatable.select("[Item] = ‘KVCARWAR-001-5000-LF’ ").CopyToDataTable
i need to use this condition on multiple dynamic values hence i need to use IN operator so the datatable can be filtered on multiple items or dynamic values like (‘KVCARWAR-001-5000-LF’,‘KVCARWAR-001-5600-LF’,‘KVCARWAR-001-6300-LF’,‘KVCARWAR-002-1130-LF’) of any count in future. so i can use a variable on this. but even for testing with one value using IN operator is giving error
This worked for me Yoichi.
i tried with one item dt_datatable.AsEnumerable.Where(Function(r) {“CBDATMIN-001-5000-LF”}.Contains(r(“Item”).ToString())).CopyToDataTable(). - it worked
tried 2 items dt_datatable.AsEnumerable.Where(Function(r) {“CBDATMIN-001-5000-LF”,“CBDATMIN-001-5600-LF”}.Contains(r(“Item”).ToString())).CopyToDataTable() - it Worked .
then i tried with dynamic values using a varaible as below
dt_datatable.AsEnumerable.Where(Function(r) in_read_filter_by_items.split(","c).Contains(r(“Item”).ToString())).CopyToDataTable()
and then tested with multiple values and the data filtered as per given values in the in_read_filter_by_items string variable = CBDATMIN-001-5000-LF,CBDATMIN-001-5600-LF,CBDATMIN-001-6300-LF,CBDATMIN-002-1130-LF,CBDATMIN-006-1130-LF,CBDATMIN-007-9600-LF,CBDATMIN-008-3900-LF,CBDATMIN-009-1130-LF
