Agentic Automation - Sort Solution Components
Hi team
I’d like to request a possibility to sort the solution components (projects). I’ve built a simple agentic solution “Customer Support Agent” to illustrate this. It contains - as indicated in the image below - two RPA Workflows, an Agentic process and an Agent.
It would be very handy to sort and/or categorize the Explorer by project type (RPA Workflow, Agent, Agentic Process, App, …).
Sorting from A-Z can get very messy in larger solutions and you’ll spend a lot of time searching for the relevant project you’d like to edit.
Many thanks!
Roman
