After [Click] activity running, the right-side page did not go into the next page and keep on this login page.
Why and how to solve?
Do you have a check app state for the login tab? If not pls do a check app then click then give another check app for the next page ui element. Give 30 sec in both check app.
Try to change the input method to hardware events and check if it works
This property would be present in the properties panel of click
@Anil_G
It doesn’t work.
Previously the error was with login button now you are showing a different button all together
Can you please tell what issue are you getting and if the previous one is solved and is this the new one?
As per error the selector might be wrong as well
Do you know what kind of wrong?
When I click [Login], this page turns into the next page .
First correct your credentials …manually login and check if they are working if yes then check if you are passinng the same values
- First check your credentials and correct them
- For password type of field we need to select secured and not standard in type into
- Then check the selectors if they are wrong …but as per screenshots looks like the credentials itself are an issue
