the assign to out_transactionItem=inWIList(in_TransactionNumber-1)
Can you show me your Invoke GetTransacionData invoke mapping and inside the that the if condition.
Seems the WIList is not having any value so its erroring out
To what value did you assign the output of ExtractWI5Items workflow?
I should be a local variable in Main like WIList with General Business Process scope
Use that same here
Thanks I heard a datarow array variable but was not sure if was supposed to use it
And in the If statement should I keep it like this
OR this
Yes, looks good.
This is how it is supposed to be:
Can you print your WIList count just before the if condition?
Also, where you have extracted the WIList have you mapped the out argument to WIList?
otherwise it does not connect
The bottom part is fine.
The issue is here:
System1 Extract Work Items
This should map to an out argument say out_WIList
Then you refresh your Invoke for System1 Extract Work Items
and assign to WIList variable that you already have in your Main vaiables
Then you are good
I think some argument has changed in your invoke GetTransactionData
Can you click on Import Arguments and then see if any thing changes/errors/blank?
Thanks Nadim.warsi
I fixed it but I still another problem now, the robot was able to open SHA1 but it closed closed it after opening and the warning message I got is this
In your Acme data scrape where you have
can you check if you are scraping correctly?
