Advanced training 3 - demo walk-though - get tranactionitem problem
The following error occurs when the Get Transaction item activity is executed:
Input value is following:
Ouput value is following:
Hi there @ColinCrabtree
Are the arguments in the Main passed correctly? :slight_smile:
Please check that the import arguments are not empty :slight_smile:
Please pass the arguments here:
Where did you take the image snap from? this is the one from the Get transaction item.
my previous 2 screenshots are details of the input and output values
Please go here :slight_smile:
You should import arguments in the Properties tab :slight_smile:
Hi There - Ok I went there and this is what mine looks like:
Good!
It looks great :slight_smile:
Well I did not change anything I just took a screen shot of what is there. So I still have the issue
Hmmm. Weird. Is the config.xlsx filled properly?
Well it seems to be as the config spreadsheet has the settings for the UipathDemo app, the credentials and the Orchestrator queuename and the Initappplications WF fires up the UiDemo app and enters the correct credentials all picked up from the orchestrator. It just falls over at the get transaction data WF. Will investigate more.
