Hi, can anyone help me into this, i have to process the data result should be write 5 times in same column
Like for Last name data there are 5 values and all appropriate values should be written only in 1 last name column for one first name.
yes ,This is input as an Googlesheet
There is one condition i have , in which it will check for 5 last name and the good one is appended in Last name as,
and then status field is marked as yes.
Like this
This would be a great use of dictionaries and lists. You can create dictionary(of string, list) and then loop through your data. You can then reference the lists the same way you’d reference any dictionary item. You can add the last name to each list.
For example, you’d have myDict(“James”) which contains a list “Bond, Cameron”
