Add data to a specific column using an array of string values
I have an array of location with 6 values lets say arr_locations= [“A”,“B”,“C”,“D”,“E”,“F”] and a datatable variable which already has some data. Lets say this datatable has 3 rows so every location must be mapped to these 3 rows.
That means at the end the total rows in my datatable would be 3*6 = 18 rows.
i/p:
o/p:
Attaching test file for your reference. Sheet1 is input & Sheet2 is the expected Output.
Testing.xlsx (10.0 KB)
@SunnyJha
  1. Read range and read data of 3 rows
  2. For each on list with arr.Take(arr.Count-1)
  3. inside loop use append range with the table read in step 1
cheers
we are depended on the col structures
assumption: Project set to Windows
Variable:
arr_locations = {“A”,“B”,“C”,“D”,“E”,“F”}
Assign Activity:
dtResult = dtOrig.Clone
Assign activity:
dtResult =
(From d in dtOrig.AsEnumerable
From lo in arr_locations
Let ra = d.ItemArray.SkipLast(1).Append(lo).Cast(Of Object).toArray
Order by lo
Select r = dtResult.Rows.Add(ra)).CopyToDataTable
UPD1 - Bracket Fix
UPD2 - Beautified it with an adtional ordering
grafik
Hi @SunnyJha
Can you try the below
Sequence.xaml (15.8 KB)
Ouput:
Testing.xlsx (11.2 KB)
I also have to mention that if you look at the last column Description which is empty in input and in the output has values from the array. That’s the main crux.
Hi @ppr ,
If you see the image I also have to assign the locations in the Description column.
we had handled this within the Linq (SkipLast(1).Append… part
