Hi!
Faced the problem of integrating FineReader Engine in UiPath. I have a trial version of FineReader Engine (Developer and Runtime licenses). Everything is set correctly (it was run on C # and Java).
When using the engine through the Abbyy OCR mechanism, I get an error that the Project ID is incorrect:
Error loading Abbyy engine. Code: AbbyyErrorLoadEngine
Fatal UiPath.Vision.OCR.OCRException: AbbyyErrorLoadEngine —> System.Runtime.InteropServices.COMException: Failed to run license SWRE-----****. Incorrect Project Id
в FREngine.IEngineLoader.InitializeEngine(String CustomerProjectId, String LicensePath, String LicensePassword, String FREngineDataFolder, String FREngineTempFolder, Boolean IsSharedCPUCoresMode)
в UiPath.Vision.Engines.StandardAbbyyEngineLoader.Initialize(String projectId)
в UiPath.Vision.Engines.AbbyyFRE12ExternalEngine.Initialize()
в UiPath.Vision.AbbyyFRECommon.BaseAbbyyFREEngine.EnsureExternalInitialization()
— Конец трассировки внутреннего стека исключений —
в UiPath.Vision.AbbyyFRECommon.BaseAbbyyFREEngine.Initialize()
в UiPath.Vision.OCR.Engine.BaseEngine.d__22.MoveNext()
— Конец трассировка стека из предыдущего расположения, где возникло исключение —
в System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
в System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
в UiPath.Vision.Core.OcrEngineRunner.d__0.MoveNext()
в UiPath.Vision.Host.Service.HostServiceWithRefContext.d__5.MoveNext()
I am sure that the Project ID is correct (I wrote in support of Abbyy, and also checked when running on Java).
How can I check which Project ID is using the UiPath? How can I fix this error?
