A way to built a UIPath solution outside the UIPath Studio
I have a command to create a package as it does in publish functionality but it doesn’t builds before creating it. Here is the command that i am using it.
"UiRobot.exe –pack " + SourceFile + " –o " + DestFolder
But the thing in this that this command doesn’t builds the solution. So, can anyone help me on how to build a solution without using the UIPath.
Thanks A Lot in Advance.
