I’m trying to Read Cell and Write Cell, next to in For Each Row. (copy B1 cell to C1 cell in loop) After compilation I haven’t the last cell in Excel. Where is a problem?
I think you have checked the Add Headers property in the Read Range activity, So you have to uncheck it.
Hey @janusz_robot
@MahalingPatil - True
As i can see in your excel there is no header present. so in your read range you have a checked Add header Property.
So while doing operation one count is less. if you will unchecked that property. it will workout for you.
Regards…!!
Aksh
